Ward's Airline 32-316
5/15/2012 8:46:43 PMJason Kritz
This weekend I was given the chassis to a Ward's Airline 32-316. The radio is a battery radio & has 3 bands. I would like to know if any of you guys have ever come across a schematic of this radio. To find the model I had to go to radio attic archives. Thanks for your help.
5/15/2012 10:27:47 PMCarl T
:This weekend I was given the chassis to a Ward's Airline 32-316. The radio is a battery radio & has 3 bands. I would like to know if any of you guys have ever come across a schematic of this radio. To find the model I had to go to radio attic archives. Thanks for your help.
Jason,
I believe the set at the Radio Attic is not identified correctly.
What are the tube numbers in your chassis?
Carl T
5/15/2012 10:52:41 PMNorm Leal
Hi
Agree with a model number like that a radio would have been made in 1923. First two numbers reversed gives year.
::This weekend I was given the chassis to a Ward's Airline 32-316. The radio is a battery radio & has 3 bands. I would like to know if any of you guys have ever come across a schematic of this radio. To find the model I had to go to radio attic archives. Thanks for your help.
:Jason,
:I believe the set at the Radio Attic is not identified correctly.
:What are the tube numbers in your chassis?
:Carl T
5/30/2012 10:42:19 AMJason Kritz
:Jason,
:Carl T
Carl,
The radio has the following tube numbers: 3(#30), 2(#34),#19, 1A4, 1A6 for a total of 8 tubes. It has 6 power input wires and a separate plug on the side for the speaker. It also has a 3 gang tuning cap. Thanks for your help.
Jason
5/30/2012 2:57:44 PMCarl T
:::This weekend I was given the chassis to a Ward's Airline 32-316. The radio is a battery radio & has 3 bands. I would like to know if any of you guys have ever come across a schematic of this radio. To find the model I had to go to radio attic archives. Thanks for your help.
::Jason,
::I believe the set at the Radio Attic is not identified correctly.
::What are the tube numbers in your chassis?
::Carl T
:Carl,
:The radio has the following tube numbers: 3(#30), 2(#34),#19, 1A4, 1A6 for a total of 8 tubes. It has 6 power input wires and a separate plug on the side for the speaker. It also has a 3 gang tuning cap. Thanks for your help.
:Jason
Jason,
I believe this schematic should work for you:
http://www.nostalgiaair.org/PagesByModel/376/M0011376.pdf
Carl T
5/30/2012 7:25:48 PMJason Kritz
::::This weekend I was given the chassis to a Ward's Airline 32-316. The radio is a battery radio & has 3 bands. I would like to know if any of you guys have ever come across a schematic of this radio. To find the model I had to go to radio attic archives. Thanks for your help.
:::Jason,
:::I believe the set at the Radio Attic is not identified correctly.
:::What are the tube numbers in your chassis?
:::Carl T
::Carl,
::The radio has the following tube numbers: 3(#30), 2(#34),#19, 1A4, 1A6 for a total of 8 tubes. It has 6 power input wires and a separate plug on the side for the speaker. It also has a 3 gang tuning cap. Thanks for your help.
::Jason
:Jason,
:I believe this schematic should work for you:
:http://www.nostalgiaair.org/PagesByModel/376/M0011376.pdf
:Carl T
:Carl T,
Thank you so much for your time & effort in searching for this chassis, you are a lifesaver. The chassis of this radio was found in my wife's grandparents smokehouse. Her brother was cleaning it up & found this chassis. I am going to do my best to restore the chassis & then will have to find or build a cabinet.
Thanks so very much
Jason
