I'm restoring a Marconi #74
I did replace many paper caps (big ones) & all the electyrolytics.
But i did not replace all the small paper caps.
Tubes are tested good.
The radio had no speaker, but fortunately it has it's audio transformer.
So i installed a 820ohms/10W résistor to replace the field coil. (i didn't increase the value of electrolytics, audio has no hum at all)
After the first test i noticed this:
B+ is a bit too high compare to the Marconi specs.
310Vdc instead of 240Vdc. Should i increase the value of the resistor ?
Audio amplifier circuit works very well.
I installed the other tubes and prepared for alignment.
At power Up, i was able to tune to some stations, but after a minute, the radio became suddenly quiet.
If i try to inject a strong signal of 462Kc at the antenna, i hear nothing at all.
If i inject the signal on the cap of the 6K7 RF stage, i hear nothing at all.
If i inject the signal on the cap of the 6A8 osc, i hear a strong signal. So i suppose i might have an open coil somewhere in the RF stage or a bad cap ?
I tried to proceed with alignment , tuning the first IF has no effect at all, tuning the second IF has effect only on the secondary side, just before the detector.
I see that the 6K7 between IF is overheating.
On my other sets, i never noticed that before.
The tube is too hot for the fingers !!!!!
i have these reading on that 6K7:(compare to the specs)
Cap:0v
Pin2: 0v
Pin3: 310v instead of 240v
Pin4: 153v instead of 95v
Pin5: 6.7v instead of 5v
Pin6: -
Pin7: 0v
Pin8: 6.7v instead of 5v
Should i check plate current drain ?
What should be the current drain on that 6K7 between IF ?
Vianney
i will replace the small paper caps too.
For now, i checked all the coils winding dc resistance. Everything is normal. No traces of oxidation on windings.
I found an open resistance R10 which is a 100K !! But no change, 6K7 still overheating.
I go for the paper caps replacement.
