changing pot value
5/6/2012 6:49:47 PMScott
Can you change a linear potentiometer value by adding carbon resistors across terminals of pot?
5/6/2012 6:57:56 PMMitch
:Can you change a linear potentiometer value by adding carbon resistors across terminals of pot?
I posted this question once before, answer that came back was no.
5/6/2012 7:11:22 PMScott
Yes, after I thought about this for a minute it proved to be a poor question. Would only be able to match needed value at peak. Oh well, going to go shopping for replacement.
5/6/2012 10:47:22 PMWarren
Philmore makes replacement on-off volume controls.
50K to 1 Meg. These are very universal. Can be used in a lot of radios. Easy to adapt extended shaft.
http://www.intertexelectronics.com/Philmore-PC385-Potentiometer-1Meg-Audio-WSwitch-24mm-P8570.aspx
5/7/2012 10:47:52 AMScott
Thanks for the resource Warren.
5/7/2012 5:41:33 PMrghines1
Below is link that looks interesting about adding a "tapering resistor" from the wiper to outer lug of a pot to achieve reasonably close audio taper. Haven't tried myself, maybe someday.
http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
5/8/2012 6:12:21 AMScott
Thanks alot for that link....really enjoyed the "tricks" section. Copier dust to repair pot..wow!
Great article and I saved in the education file.
