Storing Equipment in a Shed
5/6/2012 6:35:55 PMLou
Gentlemen:
Last fall I bought some miscellaneous test equipment at a great price and stored it in my shed on my property. I carefully stored each piece in a plastic garbage bag, and wrapped it such that SOME air could still circulate in each bag. This weekend I went out to get some of the equipment and I found a small amount of green corrosion on the aluminum surfaces of some of the equipment. The most corrosion was found on the HP equipment, which has aluminum front panels. Interestingly, the corrosion almost looks like it is NOT the aluminum but something ON it, like some other material - maybe an illusion, oils from fingers, etc?
Well, anyway how do I PROPERLY store this equipment in the meantime? I intend to remove it from the shed and get it back to the house. Should I put a dessicant package in each equipment bag? How does the military do this - perhaps this way? Thanks for any suggestions.
Lou
5/6/2012 7:56:32 PMDoug Criner
Lou, I have found outdoor, unheated sheds a problem for storing such equipment. They will be shielded from rain and snow, but their dewpoints can wind up close to the ambient temps. And, then there are mice.
Best to move everything indoors, into a heated space.
5/6/2012 9:12:18 PMJohn Kogel
:Lou, I have found outdoor, unheated sheds a problem for storing such equipment. They will be shielded from rain and snow, but their dewpoints can wind up close to the ambient temps. And, then there are mice.
:Best to move everything indoors, into a heated space.
Plastic isn't needed if the shed is dry.
A cardboard box is better than a plastic bag, IMO. Also, it is easy to smuggle a cardboard box or two into the house. :>)
5/6/2012 10:21:55 PMLou
::Lou, I have found outdoor, unheated sheds a problem for storing such equipment. They will be shielded from rain and snow, but their dewpoints can wind up close to the ambient temps. And, then there are mice.
::Best to move everything indoors, into a heated space.
:Plastic isn't needed if the shed is dry.
:A cardboard box is better than a plastic bag, IMO. Also, it is easy to smuggle a cardboard box or two into the house. :>)
JOHN !! - You do the SAME THINGS I DO. Smuggle equipment into the house!
And then when they ask " Where did that come from?", you say " Well,, thats been here for a looong time!".
Lou
5/7/2012 8:41:40 AMLewis L.
:::Lou, I have found outdoor, unheated sheds a problem for storing such equipment. They will be shielded from rain and snow, but their dewpoints can wind up close to the ambient temps. And, then there are mice.
:::Best to move everything indoors, into a heated space.
::Plastic isn't needed if the shed is dry.
::A cardboard box is better than a plastic bag, IMO. Also, it is easy to smuggle a cardboard box or two into the house. :>)
:JOHN !! - You do the SAME THINGS I DO. Smuggle equipment into the house!
:And then when they ask " Where did that come from?", you say " Well,, thats been here for a looong time!".
:Lou
Lou:
I'm lucky, I guess, mine brings home "objets d'art" (spelled junk, to me) as she calls them, for restoration, so she tolerates mine and I tolerate hers. At one time, we had $35,000 bucks worth of cars sitting in the driveway, while our carport protected $100 worth of junk. Go figger.
