4/26/2012 11:15:16 AMElton(100344:0)
I have a zenith 6s556 trying to do a voltage check and having trouble reading the schematic can anyone tell what the plate voltage is of the converter tube? I can't tell if it is 217 or 287? If it is 287 I have a problem as just hitting 200 volts
Elton
4/26/2012 12:21:06 PMWarren(100346:100344)
The plate voltage is 217. If you are reading 200 that's close enough.
4/26/2012 3:22:29 PMElton(100347:100346)
:The plate voltage is 217. If you are reading 200 that's close enough.
Cool, thanks warren!
E.
