Add an RF stage to an AA5?
4/23/2012 10:11:19 PMJohn Kogel
There's an AM oldies station I like to tune in to when I'm working in my shop. Unfortunately, there's also a mountain between me and the station. The only radios in my stable that can pull it in are the 6 tube Stromberg Carlsons and the Stromberg Carlson 1500, which has 5 tubes and a selenium (now a silicon) diode.
I want my Crosley E-15 5 tuber to be stronger on reception so I can play it more. Tell me quick if this is a waste of time.
If I replace the 35W4 rectifier with a SS diode, I can use the socket for a 12BA7. I would add a dropping resistor to the filament string. I can copy the Stromberg C 1500 schematic for my first RF amp stage.
Could I use capacitor coupling for this stage? The SC's have an extra IF trans, I believe.
Will that first stage be too close to the 50C5? Those sockets are about an inch apart on the Crosley chassis, but a shield could be added. Has anyone tried this? Of course they have, but did it work out?
4/23/2012 11:41:33 PMWarren
Did you forget about a 3 section tuner and an RF coil ?
If you really want to hod rod an AA5 check this out and have fun.
http://www.wa2ise.com/radios/12ba7.html
4/24/2012 1:17:49 PMClifton
Or perhaps use R/C coupling between the plate of the RF tube and the mixer tube input grid. Say maybe a 4.7k or so plate resistor for the RF tube and a 100K resistor between the mixer tube grid and AVC or ground with perhaps a 250pf coupling cap. Let the RF section of the tuning cap tune the RF tube control grid and loop/Ant transformer.
Clifton
:Did you forget about a 3 section tuner and an RF coil ?
:If you really want to hod rod an AA5 check this out and have fun.
:http://www.wa2ise.com/radios/12ba7.html
4/24/2012 6:15:13 PMJohn
Thanks Warren, I saw that site and will copy a few ideas. There's no need to invent anything anymore, just find it with Google.
Clifton, have you actually done what you suggest, or is this something that theoretically might work? I don't want to build an uncontrollable Frankenstein, although that could be fun, too.
:Or perhaps use R/C coupling between the plate of the RF tube and the mixer tube input grid. Say maybe a 4.7k or so plate resistor for the RF tube and a 100K resistor between the mixer tube grid and AVC or ground with perhaps a 250pf coupling cap. Let the RF section of the tuning cap tune the RF tube control grid and loop/Ant transformer.
:Clifton
::Did you forget about a 3 section tuner and an RF coil ?
::If you really want to hod rod an AA5 check this out and have fun.
::http://www.wa2ise.com/radios/12ba7.html
4/26/2012 9:14:23 AMClifton
John,
Years ago took a radio course and one of the projects was building an AM radio. It used a 6BA6 mini tube as an RF amplifier and used R/C coupling between the RF amp and mixer tube. I don't know if I still have the schematic, but I do the radio and probably could trace out the circuit for you. The radio also used a mini adjustable loopstick antenna. I later replaced the loopstick with a regular loop antenna unit.
Clifton
:Thanks Warren, I saw that site and will copy a few ideas. There's no need to invent anything anymore, just find it with Google.
:Clifton, have you actually done what you suggest, or is this something that theoretically might work? I don't want to build an uncontrollable Frankenstein, although that could be fun, too.
::Or perhaps use R/C coupling between the plate of the RF tube and the mixer tube input grid. Say maybe a 4.7k or so plate resistor for the RF tube and a 100K resistor between the mixer tube grid and AVC or ground with perhaps a 250pf coupling cap. Let the RF section of the tuning cap tune the RF tube control grid and loop/Ant transformer.
::Clifton
:::Did you forget about a 3 section tuner and an RF coil ?
:::If you really want to hod rod an AA5 check this out and have fun.
:::http://www.wa2ise.com/radios/12ba7.html
4/28/2012 10:24:25 AMJohn
I think I shall leave the rectifier as is for now and just add a 7-pin socket on a little temporary stand on top of the chassis, near the 12BE6. Then swap that with a 6BE6, with a 6BA6 for my RF amp. Thanks for the suggested R values.
:John,
:Years ago took a radio course and one of the projects was building an AM radio. It used a 6BA6 mini tube as an RF amplifier and used R/C coupling between the RF amp and mixer tube. I don't know if I still have the schematic, but I do the radio and probably could trace out the circuit for you. The radio also used a mini adjustable loopstick antenna. I later replaced the loopstick with a regular loop antenna unit.
:Clifton
::Thanks Warren, I saw that site and will copy a few ideas. There's no need to invent anything anymore, just find it with Google.
::Clifton, have you actually done what you suggest, or is this something that theoretically might work? I don't want to build an uncontrollable Frankenstein, although that could be fun, too.
:::Or perhaps use R/C coupling between the plate of the RF tube and the mixer tube input grid. Say maybe a 4.7k or so plate resistor for the RF tube and a 100K resistor between the mixer tube grid and AVC or ground with perhaps a 250pf coupling cap. Let the RF section of the tuning cap tune the RF tube control grid and loop/Ant transformer.
:::Clifton
::::Did you forget about a 3 section tuner and an RF coil ?
::::If you really want to hod rod an AA5 check this out and have fun.
::::http://www.wa2ise.com/radios/12ba7.html
4/29/2012 8:06:44 PMClifton
John,
I don't think a 6BA6 which is a 300 ma tube would light in a 150 ma series tube string. You might try a 12BA6 and maybe a 35 (35C5 ??) volt audio output tube or maybe a 6BJ6 tube.
Clifton
:I think I shall leave the rectifier as is for now and just add a 7-pin socket on a little temporary stand on top of the chassis, near the 12BE6. Then swap that with a 6BE6, with a 6BA6 for my RF amp. Thanks for the suggested R values.
::John,
::Years ago took a radio course and one of the projects was building an AM radio. It used a 6BA6 mini tube as an RF amplifier and used R/C coupling between the RF amp and mixer tube. I don't know if I still have the schematic, but I do the radio and probably could trace out the circuit for you. The radio also used a mini adjustable loopstick antenna. I later replaced the loopstick with a regular loop antenna unit.
::Clifton
:::Thanks Warren, I saw that site and will copy a few ideas. There's no need to invent anything anymore, just find it with Google.
:::Clifton, have you actually done what you suggest, or is this something that theoretically might work? I don't want to build an uncontrollable Frankenstein, although that could be fun, too.
::::Or perhaps use R/C coupling between the plate of the RF tube and the mixer tube input grid. Say maybe a 4.7k or so plate resistor for the RF tube and a 100K resistor between the mixer tube grid and AVC or ground with perhaps a 250pf coupling cap. Let the RF section of the tuning cap tune the RF tube control grid and loop/Ant transformer.
::::Clifton
:::::Did you forget about a 3 section tuner and an RF coil ?
:::::If you really want to hod rod an AA5 check this out and have fun.
:::::http://www.wa2ise.com/radios/12ba7.html
4/30/2012 9:55:55 AMJohn
Hey Clifton, thanks for that. You are right, that tube won't work. I was searching for my tube manual, as I was wondering about that very same thing. I did find a reference on the net to a 6BA6 RF amp added to a Hallicrafters ham radio, so I know the principal has merit.
I have a couple of 35C5's, so can try going that route with a 12BA6 in the front end.
First step is to adapt a 7-pin socket to the chassis without drilling any new holes. There's room for it hanging off the back, and that will keep the leads short.
:John,
:I don't think a 6BA6 which is a 300 ma tube would light in a 150 ma series tube string. You might try a 12BA6 and maybe a 35 (35C5 ??) volt audio output tube or maybe a 6BJ6 tube.
:Clifton
::I think I shall leave the rectifier as is for now and just add a 7-pin socket on a little temporary stand on top of the chassis, near the 12BE6. Then swap that with a 6BE6, with a 6BA6 for my RF amp. Thanks for the suggested R values.
:::John,
:::Years ago took a radio course and one of the projects was building an AM radio. It used a 6BA6 mini tube as an RF amplifier and used R/C coupling between the RF amp and mixer tube. I don't know if I still have the schematic, but I do the radio and probably could trace out the circuit for you. The radio also used a mini adjustable loopstick antenna. I later replaced the loopstick with a regular loop antenna unit.
:::Clifton
::::Thanks Warren, I saw that site and will copy a few ideas. There's no need to invent anything anymore, just find it with Google.
::::Clifton, have you actually done what you suggest, or is this something that theoretically might work? I don't want to build an uncontrollable Frankenstein, although that could be fun, too.
:::::Or perhaps use R/C coupling between the plate of the RF tube and the mixer tube input grid. Say maybe a 4.7k or so plate resistor for the RF tube and a 100K resistor between the mixer tube grid and AVC or ground with perhaps a 250pf coupling cap. Let the RF section of the tuning cap tune the RF tube control grid and loop/Ant transformer.
:::::Clifton
::::::Did you forget about a 3 section tuner and an RF coil ?
::::::If you really want to hod rod an AA5 check this out and have fun.
::::::http://www.wa2ise.com/radios/12ba7.html
