1936 Fairbanks Morse A
12/2/2001 5:28:47 PMJustin
Hi
I have an 8a that I am restoring. The original dial scale is made out of a thin plastic or something like that. It has warped and the edges are curling up. Does anyone know of any way to fix this? Has anyone else encountered this problem? Thank you!!!!! Justin
12/6/2001 10:11:28 AMJohn McPherson
Your only real solution is to scan, or color copy your present dial, and either make a decal transfer via color laser printer, or color laser directly onto a thin sheet of correct colored plastic.
: Hi
: I have an 8a that I am restoring. The original dial scale is made out of a thin plastic or something like that. It has warped and the edges are curling up. Does anyone know of any way to fix this? Has anyone else encountered this problem? Thank you!!!!! Justin
