Majestic schematic
4/18/2012 4:20:36 PMBob(100225:0)
Anybody in radio-land have a rider schematic # for a model 156 chassis?? 5y3,6a8,6u7,6q7,6k6.
4/18/2012 5:06:10 PMDoug Criner(100226:100225)
Schematics are usually sorted by model no., not chassis no. Can you find the model no.? If not, if you link us to a photo, we can probably identify it.
4/18/2012 6:29:24 PMBob.(100228:100226)
:Schematics are usually sorted by model no., not chassis no. Can you find the model no.? If not, if you link us to a photo, we can probably identify it.
Doug; For some reason I've noticed Majestic uses chassis numbers for there schematics,I do not have a model #. I've tried to post a photo with no luck on N/A
4/18/2012 6:55:57 PMrghines1(100229:100225)
Appears it's model 56.
http://www.nostalgiaair.org/Resources/522/M0010522.htm
Richard
4/19/2012 9:07:19 AMBob.(100234:100229)
:Appears it's model 56.
:http://www.nostalgiaair.org/Resources/522/M0010522.htm
:Richard
Thanks Richard your correct, I've noticed on Majestic radios a chassis model number is used alot, then its up to you to find model number of the radio to locate schematic.
4/19/2012 9:49:31 AMDoug Criner(100235:100234)
I used to have that model, but no longer. Very nice, but some of the components are tough to get to. I just left those alone.
4/19/2012 4:18:47 PMBob.(100242:100225)
Majestic 10-5, 3 electrolytics in schematic where are positive sides of each??
4/19/2012 5:27:35 PMrghines1(100243:100242)
It's easier to say where to connect the negative sides.
Remember the center tap of the high voltage winding is the most negative point in the radio.
Richard
4/19/2012 5:39:30 PMBob(100244:100243)
:It's easier to say where to connect the negative sides.
:Remember the center tap of the high voltage winding is the most negative point in the radio.
:Richard
Richard; The 1st Electrolytic(10@25v) would have pos to ground, is this correct?? Thats why I ask about this.
4/19/2012 6:11:26 PMrghines1(100245:100244)
Correct.
:Richard; The 1st Electrolytic(10@25v) would have pos to ground, is this correct?? Thats why I ask about this.
4/19/2012 6:25:33 PMBob(100246:100245)
:Correct.
::Richard; The 1st Electrolytic(10@25v) would have pos to ground, is this correct?? Thats why I ask about this.
thanks for the info
