Something doesn't add up: as you go from 1 ohm to 0.7 ohms, the ratio of meter reading to calculated current changes in the wrong direction. Are you sure of your measurements? The numbers you gave aren't consistent enough to be relied on for calibrating the meter.
Presumably the 301 has an internal shunt. There's not much to go wrong, that would cause such a large error. Can you verify the current with a second meter?
