Rider #8 Grunow page 41 Chassis 1191. This shorted out speaker has a buck coil,how can a speaker with no buck coil just a field & voice coil be modified or wired to work??
4/7/2012 6:27:04 PMLewis L.(100086:100084)
:Rider #8 Grunow page 41 Chassis 1191. This shorted out speaker has a buck coil,how can a speaker with no buck coil just a field & voice coil be modified or wired to work??
If you put in modern, higher value, filter caps, the hum that the buck coil is there to cancel out should not be a problem, and most any speaker that is close in field resistance and voice coil impedance should be OK. Lewis :
