Dang! hit enter again instead of tab.
Once you hae the unit under test isolated from the AC mains. grounding is no longer necessary, and in fact might be a hazard, providing a ground for other ungrounded test equipment, etc. I installed a three pin chassis jack and left the ground pin unconnected. Since the purpose of the isolaation transformer is to isolate the AC from ground, I feel it is perfectly safe to leave the green wire (ground connection) back with all the grounded AC. After isolation, Hot, Neutral and Ground have no meaning anymore.
You are correct. I was building mine from scratch, so I bought a three prong.
:Thanks Warren,
:I ask because I finally bought one and want to make sure.
:Thanks again,
:Vinny A.
