Best Regards,
Bill Grimm
I see nothing wrong with using a 50L6 in place of 35L6. Yes filament voltage is higher but this averages out over all tubes in the string. With higher line voltage using a 50L6 in place of 35L6 would be preferred.
Radios were designed in the days of 110-117 line voltage. Voltage today is closer to 120-125 volts.
::Hi Paul,
:: Warren is right. Placing a 50L6GT in place of a 35L6GT will cause all the tubes to operate with filaments that are too cool. Low emission will exist on all the tubes in the set. It will be like having a radio full of weak tubes. The result will likely be weak performance and perhaps humm.
:: I am assuming series filament, typical with a 35L6GT.
::Best Regards,
::Bill Grimm
:For test purposes, you might get by with that swap to see if you have any other problems, but I wouldn't count on it. And, I sure would not let it leave my bench that way.
:Lewis
:Norm is right. There is no real difference with using a 50L6 for a 35L6. Tubes take longer to warm, and glow slightly dimmer, but performance is just about the same. Furthermore, there is no increase in hum. I don't know why anyone would even think of that. A decrease in cathode temperature isn't going to increase hum.
:T.
As for general replacement of 35 volt tubes with 50 I tend not to do it. If the 35 volt replacement is not around then I am OK with it. My preference is for orginality and even now a proper replacement gets one closer to the proper 150 miliamperes through the filaments.
Keep in mind, removal of dropping resistors and replacement with a 50 volt tube carries the risk of heat damage to the case as noted below.
Best Regards,
Bill Grimm
I absolutely agree with Norm. I have a Granco 610FM radio that had a 35c5 for its output, with a 19T8, 12AT7, and 3-12BA6's. With 4 0.5W resistors in the filament string, it was looking for 110.3 volts total. I removed the 35C5 and put in a 50C5 and bypassed the 4 resistors. Filament string now needs 119.3 volts. Only problem I thought of was a 50C5 gets hotter than a 35C5 and may concentrate heat on the top of the case. No problems so far with over 3 years of use. Just add up the filament voltages. If you fall in the 120-125 volt range, I'd say you're golden.
Anthony
:Hi Paul
: I see nothing wrong with using a 50L6 in place of 35L6. Yes filament voltage is higher but this averages out over all tubes in the string. With higher line voltage using a 50L6 in place of 35L6 would be preferred.
: Radios were designed in the days of 110-117 line voltage. Voltage today is closer to 120-125 volts.
:::Hi Paul,
::: Warren is right. Placing a 50L6GT in place of a 35L6GT will cause all the tubes to operate with filaments that are too cool. Low emission will exist on all the tubes in the set. It will be like having a radio full of weak tubes. The result will likely be weak performance and perhaps humm.
::: I am assuming series filament, typical with a 35L6GT.
:::Best Regards,
:::Bill Grimm
::For test purposes, you might get by with that swap to see if you have any other problems, but I wouldn't count on it. And, I sure would not let it leave my bench that way.
::Lewis
:Right Norm, as usual. It will not only do no harm but will also extend tube life. Another good sub is a 45Z5 for a 35Z5.
::Hi Paul
:: I see nothing wrong with using a 50L6 in place of 35L6. Yes filament voltage is higher but this averages out over all tubes in the string. With higher line voltage using a 50L6 in place of 35L6 would be preferred.
:: Radios were designed in the days of 110-117 line voltage. Voltage today is closer to 120-125 volts.
::::Hi Paul,
:::: Warren is right. Placing a 50L6GT in place of a 35L6GT will cause all the tubes to operate with filaments that are too cool. Low emission will exist on all the tubes in the set. It will be like having a radio full of weak tubes. The result will likely be weak performance and perhaps humm.
:::: I am assuming series filament, typical with a 35L6GT.
::::Best Regards,
::::Bill Grimm
:::For test purposes, you might get by with that swap to see if you have any other problems, but I wouldn't count on it. And, I sure would not let it leave my bench that way.
:::Lewis
Lou
:Have a 35L6GT slot replaced with a 50L6GT. Tube cross reference here says a substition for both is a 70A(C). Thus, should'nt a 35L6 and a 50L6 also be interchangable, or am I missing something?
