Here are the details:
*Model PR-21
*Serial # RVG 01916
*Stamped under the warranty is 941 (does this mean Sep 1941?)
*Six tubes. All orig RCA tubes.
*Record player with a 78 setting and a 16 setting. Has inputs (Int/Ext) for other equipment (radio). Has treble, bass, and balance plastic setting knobs.
*To access the turntable, one must lift a lid. On the bottom of the lid is a green label with the dog and phonograph above the word Victorola.
*The front is a speaker, and the side rotates outward and contains another speaker, hence the "stereo".
*The front is tan stitched wicker as is the side.
*Seems to be cherrywood?
*The front says "stereo orthophonic high-fidelity dual amplifier".
*There is a two inch wide plastic pair of what looks like "wings" on the upper right front of the cabinet, which lights up when turned on.
*Seems to work electronically, but I have not attempted to get any sound to emit.
*Stands on four art deco metal peg legs (pale bronze in color; they screw off.
*Measures approx 4 feet wide and 3 feet tall.
Thanks for any help. This things is so cool. I'd love to hear all about it!! Thanks!!
It was made in Camden, NJ. Thanks.
Pauly
: I have come across a working (no needle) RCA Victor (Victorola?) cabinet record player. I'm not totally sure what to say so:
: Here are the details:
: *Model PR-21
: *Serial # RVG 01916
: *Stamped under the warranty is 941 (does this mean Sep 1941?)
: *Six tubes. All orig RCA tubes.
: *Record player with a 78 setting and a 16 setting. Has inputs (Int/Ext) for other equipment (radio). Has treble, bass, and balance plastic setting knobs.
: *To access the turntable, one must lift a lid. On the bottom of the lid is a green label with the dog and phonograph above the word Victorola.
: *The front is a speaker, and the side rotates outward and contains another speaker, hence the "stereo".
: *The front is tan stitched wicker as is the side.
: *Seems to be cherrywood?
: *The front says "stereo orthophonic high-fidelity dual amplifier".
: *There is a two inch wide plastic pair of what looks like "wings" on the upper right front of the cabinet, which lights up when turned on.
: *Seems to work electronically, but I have not attempted to get any sound to emit.
: *Stands on four art deco metal peg legs (pale bronze in color; they screw off.
: *Measures approx 4 feet wide and 3 feet tall.
: Thanks for any help. This things is so cool. I'd love to hear all about it!! Thanks!!
: : I have come across a working (no needle) RCA Victor (Victorola?) cabinet record player. I'm not totally sure what to say so:
: : Here are the details:
: : *Model PR-21
: : *Serial # RVG 01916
: : *Stamped under the warranty is 941 (does this mean Sep 1941?)
: : *Six tubes. All orig RCA tubes.
: : *Record player with a 78 setting and a 16 setting. Has inputs (Int/Ext) for other equipment (radio). Has treble, bass, and balance plastic setting knobs.
: : *To access the turntable, one must lift a lid. On the bottom of the lid is a green label with the dog and phonograph above the word Victorola.
: : *The front is a speaker, and the side rotates outward and contains another speaker, hence the "stereo".
: : *The front is tan stitched wicker as is the side.
: : *Seems to be cherrywood?
: : *The front says "stereo orthophonic high-fidelity dual amplifier".
: : *There is a two inch wide plastic pair of what looks like "wings" on the upper right front of the cabinet, which lights up when turned on.
: : *Seems to work electronically, but I have not attempted to get any sound to emit.
: : *Stands on four art deco metal peg legs (pale bronze in color; they screw off.
: : *Measures approx 4 feet wide and 3 feet tall.
: : Thanks for any help. This things is so cool. I'd love to hear all about it!! Thanks!!
: I have just obtained an older RCA Victrola Stereo like yours but I am sure not as nice.
: Yours sounds like a really nice unit. I am looking for direct replacement speakers.
: Its a Model VHT-33 W. It has Approx. 15" x 9" Bass, 4 x 6 mids and 3" Tweeters.
: As I search, I will keep an eye out for anything that might help you!
: I have you book marked!
: Pauly
: : *Model PR-21
I've just inherited what sounds like what you've come across, I'd like to find out more about it as well.
:*Six tubes. All orig RCA tubes.
:*Record player with a 78 setting and a 16 setting. Has inputs (Int/Ext) for other equipment (radio). Has treble, bass, and balance plastic setting knobs.
:*To access the turntable, one must lift a lid. On the bottom of the lid is a green label with the dog and phonograph above the word Victorola.
:*The front is a speaker, and the side rotates outward and contains another speaker, hence the "stereo".
:*The front is tan stitched wicker as is the side.
:*Seems to be cherrywood?
:*The front says "stereo orthophonic high-fidelity dual amplifier".
:*There is a two inch wide plastic pair of what looks like "wings" on the upper right front of the cabinet, which lights up when turned on.
:*Seems to work electronically, but I have not attempted to get any sound to emit.
:*Stands on four art deco metal peg legs (pale bronze in color; they screw off.
:*Measures approx 4 feet wide and 3 feet tall.
:Thanks for any help. This things is so cool. I'd love to hear all about it!! Thanks!!
